colinstubbs
newer fogs and indicators.
i've got a 1990 16v and i want to fit the newer, flush front fogs and indicators. i think it's possible, does anyone know how much of an arse is it to do?!
piece o pi$$ mate.
remove ol rubbish.
knock/cut out panel in bumper.
remove rubber grommets in support.
fit new stuff.
wont take long.
best to get stuff from GPC.
HTH :wink:
can you get clear items to match in-pro rear lights??
If you guys are apart of the yahoo corrado group...john wintle posted a clip of a 16vG60 screaming up a road. In the same directory was a picture of 2 corrados, one was probably the 16vG60 and his indicators and lamps were crystal jobbies.
Know where to get them?? 8)
pretty sure its only Buddha on this forum but on the other side of the pond who does these :wink:
Hey Sanj, seen the clip, nice car, but havent seen the pics?? sounds nice idea though..
Cheers Brian, I'll see how much GPC say... :)
Cheers Sanj, the blue G60, sits nice & LOW :D
on the other rado, the lamps look like OE late spec ones looking at the pic?
cheers dubster82, i take it that knocking out the panel is just to make the hole itself deeper, and that the rubber grommets in the support are blindingly obvious?!!! :?
got it in one.
the new fogs are slightly deeper, i persume for the adjuster mechanisms being hidden?
and the rubber grommets thing will be obvious. basically, the fogs are supported by 'pegs' that fit into the bumper, closest to the number plate. these are held into the large hole by grommets.
newer kit has larger pegs, so no need for grommets :)
any problems, feel free to talk to me on msn or PM me :)
