chris whotton
Engine cutting out
ON in the vr6 today and whilst accellerating 3000 in third engine started juddering, missing and cutting out whilst coming up to juctions on tickover.
Took of ISV again and cleaned but no change could it be ignition pack any ideas cheers.
I've got the same problem at the moment!! I've took the isv off and cleaned it out also did the same with the throttle body but still had the same problem.
Had it plugged into a computer and came up with 3 problems....
Maf has limited response
Lambda has limited response
Engine speed sensor has no signal
Might be worth having a look at them mate.
Hope this helps out, Jon
Thanks for that, will take off ignition pack tommorow and check it out , have new plugs and leads fitted ran great yesterday 70+ miles no problem been taking it steady as car has been laid up for nearly 3 years. Awsome motor forgot how good it sounds cheers Chris.
Got ignition pack off cannot see anything wrong with it unless internal,seen patern ones on ebay at £70.00 might just buy it and see if that eliminates it.
Took 2 torques screws out of back of ignition pack but cannot part the thing don't want to force it is it a sealed unit? cheers Chris.
yeah possibly, but not 100%
had a similar issue myself, coming up to a roundabout and the car starts to misfire but it did pick up and be fine for the rest of the day, same happened again the other day.
This morning the car wouldnt start at all. Turned out that the a couple of the HT leads were arching onto the pack. So check this to.
fitted new ignition box tonight, fine until engine warmed up started cutting out again on braking first but then missing all the time unable even to reach 30mph.
Any ideas what to go for next cheers Chris.
Coilpack would be a misfire and would show on vagcom if its misfiring at the point you scan - obv scan with the car running. MAF would also show on vagcom
