winchbietch
vr6 inlet elbow upgrading
Hey
just a quick one; my inlet elbow is split and looks to have slightly melted by the heat sheild, im running obd2 so the pipe is slightly smaller in diameter than the standard corrado one which i am using as a stop gap till i get a replacement.
Questions being;
Is it worth changing to the power roar etc type or just getting a factory plastic replacement? - other than just bling...
Is it also worth going down the catch can method and rerouting the pcv from the intake?
Basically those that have done the catch can route and or modified inlet elbow - would you bother doing it again?
Paul
Edited by winchbietch
I've got a Bonrath on mine, don't think it will give any benefit (apart from not melting and looking shiney)
Mine went straight on, PCV attached ok too with a bit of 'S' shaped samco hose...
