science
Missing Heated Seat Loom Connector
Just bought a heated seat loom, unfortunately it's been chopped and it's missing a connector between the dash loom and the relay loom.
The connectors that go to the seats seem to be the same plug, part no 191 972 723
Anyone know where I might get one?
VW, and yes its the same part number. I think I paid about £2 for it
Nice one!
Just thought, you'll need the terminals that go into the plug, these can end up costing the most. I used the terminals from here http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php , it worked out cheaper for me but I did make the loom up from scratch so ordered lots of bits from this place.
Can't remember which ones I used exactly but it was from this page http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/mouldingterms.php
Have a look through and see which you need. Otherwise buy them from VW but pay for the easiness
FYI, when buying the terminals cable from VW you get effectively two terminals crimped to a yellow cable, so if you need 6 terminals for the plug you should only need 3 terminal cables (if your vw is good enough, they can work out the correct type)
