Peter Harper 10 Posted June 24, 2011 (edited) I know this has been covered many times Having got the corrado... partly for the perk of having the spoiler working and then finding out it doesn't, I pulled my finger out and sorted it today I put my electrical tester to the 7 socket for ground, then tested the yellow wire and the blue/white wire to make sure it was live, everything was coming through on that fine, so I tested the switch, left the ground on and put the tested to the switch, when I pressed the switch I got a live reading so I knew it wasn't that So I knew it was the control module at fault, so with nothing to loose I took it apart and re soldered all the points, and applied new solder where it seemed low as I know dry soldered boards are notorious for breaking... it finally lives I must have pressed the spoiler switch 20 something times the day I got my Corrado in disappointment, felt pretty great seeing it finally lift up, not too sure it's working on the speed sensor at the moment but there was a live on the blue/white wire, I would advise anyone who has similar spoiler problems to do the same if they're any good wit PCB boards... if it is already broke, what do you have to loose :D Edited June 24, 2011 by Peter Harper Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 24, 2011 Nice one, you might find that blue wire connected to the radio, remove this and insulate Quote Share this post Link to post Share on other sites
Peter Harper 10 Posted June 24, 2011 (edited) Nice one, you might find that blue wire connected to the radio, remove this and insulate Is this what causes it to not work when hitting a certain speed then? I will check it out later when I go back out to it howcome the speed sensor wire goes to the stereo? my old mans got a MK4 Golf that turns the stereo volume up when you start to speed up to counter engine sound, it's not for that is it? cheers Edited June 24, 2011 by Peter Harper Quote Share this post Link to post Share on other sites
