law262 0 Posted June 29, 2011 (edited) Hi, Does anyone on here have advice on the proper place to fit an oil pressure sender on a G60? I have fitted mine on the side of the head, where the OEM low-pressure switch and charger feed is. Does anyone know what the psi should be for an engine thats reached operating temp? My gauge shows all different pressures in relation to RPM when oil is cold but, as soon as it gets hot (80 - 100c) it doesn’t move much at all (stays 10 - 15 psi). Thanks Edited June 30, 2011 by law262 Quote Share this post Link to post Share on other sites
