bigt 0 Posted July 4, 2011 hi corrado peeps i have a 94 vr6 for over a year now after seeing mates g60's and loved them i have changed the front pass side bearing drivers has been done 1 year ago drop links done both sides wishbone bushes both done problem still is there is a whheeering noise over 40mph that sounds like its the wheel as repeats faster if you go faster mate has jacked it and gone up to 70mph and still hears it i had an advisory on the big cog thing that comes out the gearbox is this the gear box on the way out ? thanks Quote Share this post Link to post Share on other sites
boost monkey 0 Posted July 4, 2011 input shaft bearing for the gearbox? does the noise go away if you push the clutch pedal in? Quote Share this post Link to post Share on other sites
bigt 0 Posted July 6, 2011 Noise is still there with clutch pressed down Quote Share this post Link to post Share on other sites
Wendy 0 Posted July 6, 2011 Do you have discs with the holes in ? If so, when your press the brake is the noise louder and then without the brake on, the same noise but less noisy. A bit of a whoosh sound like air being forced through a gap. If so, it is your brake disks. I have had this since putting on new discs with holes and it is driving me insane. Quote Share this post Link to post Share on other sites
bigt 0 Posted July 6, 2011 i have dimples and slots in my discs that wernt the most expensive ones ie ebay it does get louder when breaking but thought it might be the breaking noise aswell i have spun the wheels jacked up and it does catch the discs as it goes round Quote Share this post Link to post Share on other sites
dannyboy 0 Posted July 6, 2011 make sure the driveshaft nut is done up on the hub to 240-260 nm. mine done that and had wheel bearing drone noise,because i didnt do the nut up tight enough. Only noticed it when i was getting new tyres put on. Quote Share this post Link to post Share on other sites
