Swompy
problem with lights on a golf
Right I've got a bit of a problem with my golf (mk3)
When ever I have the indicators on they work fine but as soon as I put my foot on the break they stop. The same happens if I put the hazards on, also when I apply the break the light to indicate the fog lights are on turns on as well.
So where should I start?
Try looking at the rear light bulbs on both sides, substitute a spare into each position and test, then move to the next position. In one position it may clear the problem.
Sometimes a faulty bulb causes an alternative earth path through another bulb filament.
