mccurl 10 Posted July 20, 2011 i have just had my G60 engine reconditioned about 2k ago, everything was fine up to the other day. now instead of idling at 7/800 rpm it is now idling at 13/1400 rpm any ideas? Quote Share this post Link to post Share on other sites
Album56 0 Posted July 20, 2011 False air getting in to the induction side, check vacuum hoses & make sure idle screw is still in place to start with. Quote Share this post Link to post Share on other sites
mccurl 10 Posted July 20, 2011 thanks Album56, i'll check and get back to you! Quote Share this post Link to post Share on other sites
S13eydg60 10 Posted July 13, 2016 Hi there I have a similar problem with my g60 revs sticking at 1400 or so checked and replaced vacume hoses problem only seems to happen when on a cold start any suggestions thanks Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 14, 2016 Also check those Daft Little micro switchs that often come adrift and move. Possible Sticking idle valve, pull out the idle screw and wrap a few turns of Teflon tape to the screw, if its gone awol you'll hear a whidyling noise at idle. Quote Share this post Link to post Share on other sites
