pet73r
Early Corrado in Green?
Hi guys, looking to buy a n/s early wing, seen one online and been assured it came of a 'G' or a 'H' reg car which would make it an early one right? Only Problem that it is green, I thought that the only corrados that came in green were late ones finished in Dragon Green.
Can anyone confirm this? Can you get an early corrado in green?
There are several greens made in different years:
Dark Green Metallic ----------------------LD6U ---------------------90
Green Pearl Effect ------------------------LC6V ---------------------90 - 93
Khaki Pearl Effect -------------------------LC6Z --------------------92 - 93
Classic Green Pearl Effect ---------------LC6U ---------------------93 & 95
Dragon Green Pearl Effect ---------------LC6P ---------------------94
Yes could have been. Most likely is Green Pearl Effect. You could always ask the seller what the colour code is and that may give you a better confirmation. The colour code should be on a sticker in the boot and it should match one of th codes above.
