dietztho000
Banjo Bolts for G60
Im looking for the banjo bolts for the oil supply and return lines on the G60 charger. I need the bolt that connects the supply to the engine, the supply to the charger, and the return line to the charger.
Thanks!
Get new teflon lines if you havnt already. Around £20 from gwerks i seem to remember.
Edit - they can supply the banjo bolts with it, just incase that wasnt quite clear
