Rich 0 Posted March 8, 2004 I need a new flywheel for my 16v, does anyone know where I can get one? Does it share the same flywheel as a Golf? Thanks! Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted March 8, 2004 I doubt it, as the golf will be on an 020 rod change box. what's up with yours? can't you have it skimmed? have you considered a lightened one? Quote Share this post Link to post Share on other sites
Rich 0 Posted March 8, 2004 Some of the teeth on the flywheel are a bit knackered. Which means sometimes when I try to start the car it doesnt catch, and you get this high picthed squealing sound! Excuse crap description, but my knowledge of cars is low... This means I have to stick the car in gear and rock it forward a bit. This usually sorts the problem out, but is more hassle than I want! Doesnt happen every time, but is becoming more often, so want to sort probelm out before it gets worse... Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted March 8, 2004 get a new ring gear for the flywheel then, it's a seperate peice Is the starter motor OK? Quote Share this post Link to post Share on other sites
Rich 0 Posted March 8, 2004 The starter motor is fine as far as I know. Where can I can a ring gear from? Thanks for your help Quote Share this post Link to post Share on other sites
Henny 0 Posted March 8, 2004 have a word with C&R enterprises... I got my 16V flywheel for my MKI 16V from them when I was at Uni for a good price... 8) Quote Share this post Link to post Share on other sites
funky 0 Posted March 8, 2004 that high pitch squeling is definetly the starter motor it happens when the starter spins and doesnt engage,take it off give it a good clean with some solvent do not grease or oil as clutch dust will do the same again in no time and refit hth funky Quote Share this post Link to post Share on other sites
Rich 0 Posted March 9, 2004 Thanks for the advice. Will clean the starter motor. Fkywheel is definitely in need of replacing though as well I have found a cheap flywheel, but there are two types apparently for the 16v the gut told me.....all the guy could tell me is one was lighter and one was heavier....which one should I get? Does it matter? thanks! *complete car novice* Quote Share this post Link to post Share on other sites
big_mac 0 Posted March 9, 2004 the lighter one will let the engine rev easier and will improve engine braking at least thats what i got told when i was looking for a lightened flywheel. Quote Share this post Link to post Share on other sites
