trevyt
coilivers with mk3 vr6 top mounts
hi to all
just want to clear up my confusion, i am going to fit coil-overs and want to know the part numbers for the bit i need from the vr6 (93 -95?)top mounts.
this is what i think i need starting from the top and working down:
N 0221501 nut
357412319B limit stop
357412331A top mount rubber
1H0412365A threaded bush
1J0412249 bearing
357412341A spring plate (not sure if i need this ?)
doing this upgrade as not running vr6 but 16 valver
any info would be good and very very usefull
also for info if you want free access to etka join vagcat.com and you then have it .
cheers
