harryc 0 Posted August 18, 2011 Its p!ssing down with rain outside so i dont want to start pulling all the fuses and checking relays. Having been working fine and never been an issue suddenly both windows and central locking have died. There is no solenoid noise from the electric windows, they are literally dead. Same story with the central locking... Trying to sell the car this week, bloody typical! Is this more than likely a fuse? Im at my girlfriends with no tools so hoping its just burnt one out. It is very wet outside.. Quote Share this post Link to post Share on other sites
RW1 0 Posted August 18, 2011 (edited) Fuse 4 - 15 amp (blue) C/Locking Fuse 14 - 10 amp (red) Windows Fuse 52 - 20 amp (yellow) C/Locking & Windows [located up above the two rows of relays] If any pops again.... you've got water in door motors or the rear right quarter panel sill where the window controller is. . Edited August 18, 2011 by RW1 Quote Share this post Link to post Share on other sites
harryc 0 Posted August 18, 2011 ARe they likely to have all blown simultaneously? I was in the car and windows were fine, started it again 5 mins later and suddenly no windows and no central locking! Quote Share this post Link to post Share on other sites
RW1 0 Posted August 18, 2011 I think no. 52 is most likely as its common to both Windows and Locking. I've just given you all the circuit's fuses. . Quote Share this post Link to post Share on other sites
harryc 0 Posted August 18, 2011 cheers matey will go check it out when it stops pouring.. Quote Share this post Link to post Share on other sites
RW1 0 Posted August 18, 2011 Tell me you have not bought that Scirocco with a red dash dials? . Quote Share this post Link to post Share on other sites
harryc 0 Posted August 18, 2011 Which one mate? Got a 2yr old used approved 2.0 TSI GT from VW Quote Share this post Link to post Share on other sites
RW1 0 Posted August 18, 2011 Illumination centre MFD lettering. . Quote Share this post Link to post Share on other sites
harryc 0 Posted August 18, 2011 Still confused!? As per standard spec or optional extra? Its an 09 plate? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted August 18, 2011 Alright Harry, how did the degree turn out? There's a controller unit behind the OSR door card. It controls both the central locking and the electric windows. If you have no luck with the fuses and relays, this should definitely be your next point of contact. Pull the doorcard off and you'll see it right in front of you :-) Quote Share this post Link to post Share on other sites
RW1 0 Posted August 18, 2011 Ah, it has white display lettering in the MFD. The centre rectangle information display between the speedo & rev counter. If it was a red MFD display lettering........ the windows go up and down when ever it rains or you wash the car. So you would have felt at home given the Corrado is grumbling cos you should be keeping it! Fixed it? . Quote Share this post Link to post Share on other sites
harryc 0 Posted August 18, 2011 boost monkey said: Alright Harry, how did the degree turn out? There's a controller unit behind the OSR door card. It controls both the central locking and the electric windows. If you have no luck with the fuses and relays, this should definitely be your next point of contact. Pull the doorcard off and you'll see it right in front of you :-) Ended up with a 2:1 (by 0.1%!!!) How did you get on? Thanks will definately have a look if the fuses aren't to blame. RW1 said: Ah, it has white display lettering in the MFD. The centre rectangle information display between the speedo & rev counter. If it was a red MFD display lettering........ the windows go up and down when ever it rains or you wash the car. So you would have felt at home given the Corrado is grumbling cos you should be keeping it! Fixed it? . Ha! Would go nuts if that happened in the new rocco! Havnt had a real chance, had a brief dig about but couldnt locate the fuses above the relays whilst in the drivers seat. Im slightly worried that the cause is the eastern european car wash i took it to yesterday. They seem to enjoy blasting the car from an inch away with several pressure washers ata atime, they gave one of the alloys a proper battering! Im thinking they may have forced water through seals and into the bodywork.. Quote Share this post Link to post Share on other sites
RW1 0 Posted August 18, 2011 (edited) Quote had a brief dig about but couldnt locate the fuses above the relays whilst in the drivers seat. Its this one... [ATTACH=CONFIG]48716[/ATTACH] . Edited August 18, 2011 by RW1 Quote Share this post Link to post Share on other sites
harryc 0 Posted August 19, 2011 ^ Got it in one! On mine the fuse is located just above the 53 relays as appose to next to it but sure enough it was burnt out. New fuse = no problems! Thanks guys. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 8, 2011 Hey mate, I scraped a 2:1 aswell, my average grade just says 60%! So glad it's all over tbh. Didn't even go to Grad in the end! Quote Share this post Link to post Share on other sites
