Alex_G60_Fanatic
MFA mpg not working...
just reads 99.9mpg all the time...
checked the back of the clocks and the vacuum hose was attached and looked fine... where does the hose go to in the engine bay and what else could be causing this? :thumbleft:
It's one of those weird corrado gremlins. It usually sorts itself.
Could always try resetting the clocks by disconnecting the battery
there's vac lines going into and out of both the clocks and the engine, my brother from another mother. Get under that hood!
I think there might be some info on this site about it. If only someone designed a search.
p.s. you owe me cake.
I've already had the battery disconnected loads of times... It's not working since I bought the car
No cake for you!
I know there is a vac line in the engine bay but where is it?
