Crispy Squirrel 0 Posted September 5, 2011 It goes from off to dimmed. Thats it. It was working fine the other day but now it just doesn't want me to push her in. Its like it jammed off or something?!? Anyadvice ?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 6, 2011 This is how they break = plastic goes brittle inside and cracks If you open the switch up you may be able to get the remains out and get the switch working again but a new one is the best way to go - see the group buy! Quote Share this post Link to post Share on other sites
monzablau16v 0 Posted September 6, 2011 (edited) try this : http://the-corrado.net/showthread.php?57486-Late-Headlight-Switch....Its-Happening.&highlight=switch+headlight or this: http://the-corrado.net/showthread.php?12494-Headlight-switch-repair-a-pictorial-guide&highlight=headlight+switch+repair ohh and don't forget this... http://the-corrado.net/showthread.php?49497-Headlight-switch-and-loom-fires.....DIY-prevention&highlight=loom+fire Edited September 6, 2011 by monzablau16v Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 6, 2011 i would remove it asap before it burns out the wiring, thats what happened to mine Quote Share this post Link to post Share on other sites
owen g60 10 Posted September 6, 2011 mine does this and it turns out it moves itself back into the dash as the clips are wearing out.. would try to pop it out and see if it works outside the dash. i have padded the hole to keep it in the correct position Quote Share this post Link to post Share on other sites
RW1 0 Posted September 6, 2011 Padding out the body of the switch will prevent it working. The plastic side walls are thin and distort easily. Plus you could cause the internal slider contact plate to slew. Thats when you get a short and you soon know about it with a loom wrecked in a blink of an eye. Put the earth wire fuse in....... . Quote Share this post Link to post Share on other sites
owen g60 10 Posted September 6, 2011 already done the earth wire... is only some thin padding stopping the switch sliding into the dash Quote Share this post Link to post Share on other sites
