ray_vr6
Oil Pressure Gauge Wiring
I am going to be fitting a 10 bar oil pressure gauge to my 1990 16v and I'm sure I read some where that there well maybe wiring within the existing loom to facilitate the gauge - does anyone know if that is the case or is it just as eay to run a new wire to the sender?
If its there, in the engine bay near the starter look for a loose single connector with a Blue with White stripe wire.
Ends up at a connector behind the fuse/relay plate. If it carries on to the centre console, its a Blue with Yellow stripe wire.
