vw_john 10 Posted September 12, 2011 I have an early C, and the direction slider for where the air is directed doesn't go to either end it will move freely in the middle but never reach far right or far left. which is annoying cause i need to demist the front screen! cheers Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted September 12, 2011 sounds like the bowden cable for the screen demister has kinked thus not moving as freely as it should, not sure that these are available anymore though from the stealers, I had the same problem on my corrado (late controls) which eventually lead the the failure of the controls them-selves due to the cable not moving freely... Quote Share this post Link to post Share on other sites
Jim 2 Posted September 12, 2011 Having helped Supercharged dismantle his interior a few weeks back to do a heater matrix, we got a pretty good understanding of what makes the heater controls work (or not work). I'd be very surprised if there is anything wrong with the slider controls / the front panel itself. It'll most likely be the bowden cables than link the controls to the heater box. Your problem will be getting to them, getting them all out... you REALLY need the heaterbox out to do a proper repair / investigation as the mechanism / cogs are all on the UNDERSIDE of the heaterbox - a spectacular piece of design by VW! If you really want to get properly to the bottom of heater control issues, it really is a days work pulling apart most of the interior :( Quote Share this post Link to post Share on other sites
vw_john 10 Posted September 12, 2011 Quote If you really want to get properly to the bottom of heater control issues, it really is a days work pulling apart most of the interior ...more work for the rado then. Think I might try not to breath when the cars cold. thanks for your quick responses though! I might get round to doing it this week as shes not going anywhere for other reasons. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted September 12, 2011 I've been able to replace the demister cable by just removing the trim on the drivers side, if you unhook one end of the cable, you will probably find that the the sliders work fully as a test :) Quote Share this post Link to post Share on other sites
tony_ack 0 Posted September 12, 2011 Yep you can get the cables out by just removing the lower dash, though access isn't great. Be careful not to snap the control flap levers! Quote Share this post Link to post Share on other sites
rodmax 0 Posted September 12, 2011 Hi i still have the complete slider & cable assy.let me know if you need it thanks rod Quote Share this post Link to post Share on other sites
budhilton 10 Posted September 15, 2011 (edited) I have the same problem on a 95. As a temporary solution I have disconnected the windscreen cable and closed it on the windscreen. I now just use the second vent cable. This means the vent to the windscreen will always be open but I can still direct air to the other vents. I will eventually replace the cable but it will do for now. I found when stripping it out that the hvac control unit itself was fine. Thank god for that as they seem very expensive and hard to get hold of Andy Edited September 15, 2011 by budhilton Quote Share this post Link to post Share on other sites
