TheDukeGTi
Electric windows only go up half way.
Hi all.
Hoping I could get some help if possible?
I've got an early spec Corrado 16v and my drivers window is stuck at the bottom. If I try to put it up, it goes up about a third of the way then gets stuck. When it gets stuck, there's a grinding sound, almost as if its got a stone stuck in one of the runners.
Anyone had this problem? Any diagnosis at all?
Is the door just one mold or can the two metal halves (i.e. the body work and inner frame) separate? Its not particularly an easy thing to get to!
Thanks in advance for the help!
Edited by TheDukeGTi
I think I'm going to replace the whole thing, its just going to be easier. The electric windows, are they rado only? Or will a Mk2 one do. Also, are the early corrados the same as the late corrados as far electric windows are concerned (apart from switches obviously)?
The door is one mould, you get the mech out through the top, if you need advice in swapping it over give me a pm
