emu
VR6 - Black smoke under hard acceleration and massiv oil usage ??
Car is using massive amount of oil, what I mean is about 2-2,5 liters every 1k miles :( - Defo no leaks
Under hard acceleration smokes badly in black, big black cloud behind a car
What's wrong ?? Piston rings gone ??
Car pass emission test with excellent results and has around 165k miles on clock.
  Fulltimejunglist said:
check oil cap for spunk, could be head gasket...
headgasket fine, no water leak, no water in oil, no oil in water
---------- Post added at 10:17 PM ---------- Previous post was at 10:16 PM ----------
  Supercharged said:
Compression test?
have a tester but it's raining all the time is north Scotland now and when is sunny I'm at work :( Will check it anyway but it takes some time probably.
Valve stem seals isn't it if you're using oil and getting a load of black smoke?
head was reconditioned about 2 years ago, forgot to mention that
  KADVR6 said:
piston rings i'm afraid
That what I thought but will do compression test anyway. Finally will find a use for my 3l new bottom end :) but when it happens, nobody knows :(
  floppyman said:
Were valve guides done?
new valve guides by previous owner, forum member so have no point not to believe.
  Supercharged said:
I think it's got to be rings with that oil usuage... 165k is a lot of miles on a VR!
I know that but have another one with 187k miles and oil usage is about 200ml on 7k miles. I was very shocked about that.
After i had the the head rebuilt on my VR it was using about 2-2.5k in 400 miles. Took it back to the garage and just before they were going to remove the head they found that a breather pipe was completely gunked up. Cleaned it out, and presto engine worked a treat, oil consumption dropped and no more smoking.
Worth a check before in case it is something as easy as this.
