webbywagon 10 Posted September 24, 2011 Well after much swearing and crying, ive managed to get my siezed G60 calipers off the hubs. Ive managed to eventually get the pistons to move out, and there looks to be corrosion on the pistons surface. Are they servicable or would i be better getting decent second hand ones. Also where can i get a service kit from, GSF anygood. Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted September 24, 2011 They are serviceable VW do seal kits for them, you could completely pop out the psiton and have a look at the pistons if they are really bad then price up new pistons as well, if its gonna be expensive price up a new set of callipers and see what they would cost, other option is to get a decent set of second hand ones and strip them down and reseal them, that way you might save on haveing to replace the pistons, as I am not sure how much they would cost. If you are replacing the seals then you will have to factor into the price a piston winding tool. It depends on your time also, if you need them ASAP then buying new ones would be alot easier Quote Share this post Link to post Share on other sites
webbywagon 10 Posted September 25, 2011 Drivers side is in need of a new seal and the piston needs cleaning. Passenger one looks ok. I think i might either get some replacements, or do what i did on my mk2 GTI 20VT, and use Porsche Calipers again. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted September 26, 2011 do VR calipers fit? if so i have some going as ive just done my brakes....... Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 26, 2011 Rear calipers are the same i believe, but if the OP is referring to the fronts they're different Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 26, 2011 G60 callipers are the same as VR6 (corrado) - VW do them exchange for a very good price! Quote Share this post Link to post Share on other sites
