davie 10 Posted September 30, 2011 ive hids fitted which stopped working today, checked the fuses and now i have NO lights at the front of the car... rears work fine... please help i have no idea were to go from here, fuses are fine Quote Share this post Link to post Share on other sites
davie 10 Posted October 2, 2011 nobody ?.... can any1 even tell me if there is a relay for the lights ? kinda need my lights working Quote Share this post Link to post Share on other sites
elliott 10 Posted October 2, 2011 I know nothing about hid lights but if your fuses are all OK then check for relays around the battery. Most corrados have got some kind of wire upgrade and you might find your problem with the upgrade if not done right. You should have a separate relay for each side so as you have nothing it could be a dodgy wire going to the battery? As were talking hid I'm not sure but you might at least have side lights? Quote Share this post Link to post Share on other sites
monzablau16v 0 Posted October 2, 2011 is the original OEM headlight loom plug still intact? If so, grab some H4 bulbs and put them back into the headlights and then connect the original loom into the unit (basically bypassing the HID ballasts, bulbs and any other non-standard wiring) If that all works then you can narrow it down to faulty ballasts or other wiring. Quote Share this post Link to post Share on other sites
davie 10 Posted October 2, 2011 thanks.. i was thinking along those lines, only issue was that when the hids failed all the oem sidelights, foglights etc still worked, by checking the fuses and starting the car again i had nothing at all, thing is the sidelights and hid's aint connected and run seperate as normal with a car with hids. so is there an actual relay for the front lights? if so were is it located. will check the back of the switch tomorow for the earth wire Quote Share this post Link to post Share on other sites
davie 10 Posted October 3, 2011 ok, had the switch out and all is fine with that. still dead up front . is there a relay that would cause this ????????? ---------- Post added at 11:31 AM ---------- Previous post was at 10:23 AM ---------- right.... managed to get all the original lights working :) so im guessing the hids failed, pretty annoying as they are ment to be 1-2 months old Quote Share this post Link to post Share on other sites
