davie
advice needed please
i posted this on friday, dont know if any1 seen it, anyway i have no lights working on the front of the car... rears work fine, any ideas? all fuses are fine, is there a relay that could cause this? started off with the hid's failing then total darkness up front
Is the headlights switch ok? Pop it off and check the wires behind. Also check if someone has fitted a fuse on the earth into the switch (common mod) and see if it needs replacing.
thanks will check that out, i figured the switch was ok as the green light on the switch still illuminates.... although im new to the cars so dont know if that means anything or not?
