Zonda_
Urgent help needed! 2.0 16v
Hi all! I've just got an engine from a 2.0 16v Corrado to put in my MK1 Golf. The problem is the rough sods who took it out of th ecar have succeeded in chopping through everything except the metal bits! The wiring harness is screwed, they've knocked the dizzy off and a few other bits.
I have no idea what's missing/damaged etc and the guy who is fitting it for me needs a wiring diagram and pics to try and sort it. I know Haynes dont do a manual for the Corrado but I was hoping someone on here would have some good detailed pics and wiring diagrams or know where I could get them.
Thanks in advance.
The attached zip files have pdf's of all sorts of wiring diagrams, click the download buttons.
IIRC the Passat also used the same 2.0 16V engine... simply go out and buy a passat haynes manual. That's got all the info in it for the 2.0 16V engine and will have all the wiring diagrams you need to get the engine running... 8)
You need a 91-96 passat one... 8)
