iamsilverfox
timing advice on a kr
ive done a good few searches but still need a little confirmation. to set timing on my kr i;
-disconnect the red lead by coil and block breather
-start her up, let it warm to 80C and set idle to 1000rpm with idle screw
-plug strobe on cylinder 1 and point at the flywheel under the green bung
-adjust dizzy until the strobe flashes on the small marker after the larger diamond?
[ATTACH=CONFIG]49716[/ATTACH]
big red diamond being before tdc and smaller diamond tdc?
is this right or am i missing something?
