Julien 10 Posted October 21, 2011 Hi everyone, As I couldn't more to ride a MK4 TDI, I decided to buy a rado for 4 months now. So it's a 91' G60 with 137000Km. It has all the classical options. Unfortunately the day I bought it, I had an engine problem. A very strong rattling came from the bottom and everybody guess the following The cause was a seal of the compressor that was not in the good place. Presently there are : ENGINE : - 16v gearbox - JABBA stage 2 - 68mm pulley - Outlet RS kit - By-pass group A - W6DPO - SKF High Flow water pump - FPR porsche 944 - VENAIR hoses kit - KW suspension INTERIOR : - HI-SPEC phantom oil temp gauge/oil pressure gauge/compressor pressure gauge - VR6 Intérior EXTERIOR : - VR6 front bumper - VR6 hood - Red/Crystal tail light After a check of the engine, I had to change the crank so I decided to build a 16VG60 but after a moment, Idecided to replace the G60 by a M90 Eaton. I'm still building it and will soon post pictures of the parts... Here are pics of the car few days before I got it : Quote Share this post Link to post Share on other sites
aide 0 Posted October 21, 2011 nice clean bay, be good to see another supercharged 16v on the site too. keep us updated on the build. Quote Share this post Link to post Share on other sites
Julien 10 Posted October 22, 2011 Thanks. I will update it as one goes along So to check where does the rattling came from exactly I opened the engine block. As you can see, there was so much metal shaving... The corrado during the operation Then the block where you can see that the crankshaft is marked Look at those con rod bearings... The metal shaving... As I wanted to do a 16VG60, I decided to buy a 16v KR engine to fully rebuild Quote Share this post Link to post Share on other sites
Julien 10 Posted October 25, 2011 My rado during the disambling of the engine The springs and valves of the cylinder head and a lot of parts :lol: Then I painted the coolant reservoir. Quote Share this post Link to post Share on other sites
Julien 10 Posted October 25, 2011 And the car without the engine Quote Share this post Link to post Share on other sites
