DELG60 0 Posted March 15, 2004 I want to put some alloys on my G6o and am new to this can somebody please tell me what the wheel size on a G60 is and what size tyres I can fit I want to stay with a 15 inch rim and have currently got 195/50/R15s Any help with offset,Pcd.Et etc would be appreciated Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted March 15, 2004 fitment is 4x100 with a 57.1 bore. offset (ET) should be 35-38 standard. anything down to ET25 should fit without arch work. try and avaoid going higher than 38, they'll sit in the arches too far and look silly. Quote Share this post Link to post Share on other sites
DELG60 0 Posted March 15, 2004 Thanks for the information with regard to the tyres can i change from a 195/50/15 to a 205/45/15 and what exactly is the difference? Quote Share this post Link to post Share on other sites
Henny 0 Posted March 15, 2004 195 = width in mm 50 = percentage of width that the side wall of the tyre has (ie on a 195 50, the side wall is 50% of 195mm) 15 = inner diameter of the tyre (the actual outside diameter of the wheel it's fitted to) in inches... 8) 205 will be 10mm wider... the 195/50 will have a side wall of 97.5 mm, the 205/45 will have a side wall of 92.25 which will mean that your rolling diameter of the wheel will be less than with your existing tyres.... this will mean that your speedo will over read slightly... :? Quote Share this post Link to post Share on other sites
