cobbvo 10 Posted October 27, 2011 Hi there my drivers door lock barrel came out with the key the other day is there anyway to repair it and keep the same key? Cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 27, 2011 Yep, if you buy a new barrell it will come with a key but you simply need to (carefully) swap the levers over from the old to the new, when you insert the Key they should all go flush. Good idea to also buy a blank key and get it cut too if the old one is worn. Quote Share this post Link to post Share on other sites
tony_ack 0 Posted October 27, 2011 If it came out with the key then you're missing the circlip on the back of th barrel - you shouldn't need a new barrel? Quote Share this post Link to post Share on other sites
Wullie 1 Posted October 27, 2011 Or you could simply swap the old barrel into the new one, assuming you still have the old one. Quote Share this post Link to post Share on other sites
cobbvo 10 Posted October 27, 2011 Is the barrel the same as in the mk2golf ? ---------- Post added at 02:45 PM ---------- Previous post was at 02:42 PM ---------- It has actually snapped at the circlip Quote Share this post Link to post Share on other sites
