liamtg60
help
can someone identify this engine sensor for me please the lug has snapped off it and it needs replacing 1.8 16v thanks
[ATTACH=CONFIG]49909[/ATTACH]
there are 3 sensors in that area that are exactly the same, one is for your ECU, ISV, and coolant temp gauge
you will see that they look the same, you can swap the terminals around on all 3 sensors.
Vw still stock them, when you buy a new one be carefull when installing and don't over tighten it.
