stevef182
Passenger door wont open
I can no longer open the passenger door from the outside (opens fine internally)
I have already replaced the common faulty part with one of Daves door handle repair kits, which worked for a while, and the piece still seems to be in order. But from what I can see (having had a very quick look yesterday) is that the arm that presses the catch behind the handle now isnt moving down itself all that much when the handle is pulled. Part of the handle looks as if it has broken, and when i look at the catch inside the door it does move a bit when i pull the handle but not enough to release it fully.
Is it easiest just to replace with a new handle and then re-tumble the lock?
