APJ 0 Posted March 16, 2004 my 92 'rado 16v has got some sort of idling problem, when i stop in traffic when the engines warm the idle speed will drop to the lowest point above zero and the engine struggles, it drives fine other than this bt this is becoming an annoyance :( Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 17, 2004 Is it a KR or 9A? The KR you can adjust, the 9A you cannot. On a 92 I expect it's a 9A. You could try and clean out the ISV. Make sure also that the closed throttle switch is working and teh throttle cable is not too tight. Gavin Quote Share this post Link to post Share on other sites
