AndyCorradoVR6 10 Posted November 24, 2011 Driving today and the battery light started flashing, as that had caught my eye I then watched as the oil light begun to flash. Then I lost power and had to pull to the side, but as I was pulling to the side it seemed to find itself and I slipped it in second and set off on my merry way. Everything was fine. Then on the way home it's just done it again. Flipped the hazards on, the engine still runs but if I put it in gear, no power. Switched engine off and restarted and everything was fine again. Any ideas people? Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted November 24, 2011 check battery connections are tight? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 24, 2011 Yeah sounds life when my battery wire came loose Sent from my X10i using Tapatalk Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 24, 2011 Surely if power is lost from the battery, even just due to loose connection, no lights would flash and engine would cut out due to no spark?? COuld it be the alternator on the way out and you drained the battery - wouldnt take long to drain the battery thats not been charged by the alternator. Maybe its an intermittent alternator issue. Quote Share this post Link to post Share on other sites
