yacobwood 0 Posted January 18, 2012 My nearside rear light has decided to fail me. Defiantly not the bulb at fault. Brake light works, just the rear light (when foot off brake) doesn't. I highly doubt a fuse would only be to that area so im led to believe its a wiring fault...... Any help welcome =/ Multiple Bulbs and cluster thingy me bobs tried Quote Share this post Link to post Share on other sites
tentonhammer 10 Posted January 18, 2012 Each tail light is fused yes. Brake lights are independant and share their own fuse (position 20, 10Amp) I had a nearside tail light go out a couple of weeks back, fuse had blown. Check position 7 on your fuse board (counting from the left). 10Amp fuse required. Ten Ton Quote Share this post Link to post Share on other sites
yacobwood 0 Posted January 18, 2012 Ahhh i stand corrected. I will have a look at this. Thanks ---------- Post added at 12:36 PM ---------- Previous post was at 11:46 AM ---------- Result. All fixed :) Quote Share this post Link to post Share on other sites
tentonhammer 10 Posted January 18, 2012 A simple fix. Good job! Ten Ton Quote Share this post Link to post Share on other sites
