dochy
cleaning supercharger boost pipes
has anyone cleaned the boost pipes from the charger to the intercooler etc??what is the easiest and best way to do this??cheers.
its the inside of them!!looks like a bit of a cnut!!!bought a g60 with a foolked gharger and the inside is caked in bad oil!!need to clean before i put new charger in!!
Disconnect them from the charger, throttle body and intercooler and remove from the car. Blast through with some degreaser and a jet wash
If you have enough degreser you could try steep the pipes and intercooler in it over night. I know the gegreases I have used only really works if you work with a brush while using the degreaser.
