seafar99
Shortshift question.......
Howdy, Probably been covered loads of times but what options have i got fitting a short shifter to my gear linkage?
The corrado has the original 1995 16v gearbox but has had a 20v 1.8T engine conversion, any helpful links/costs
would be appreciated. It really does feel like a long throw between gears.
Thanks Craig.
cut and shut on the relay plate at the bottom of the gearlever is a good option, it moves the pivot point for the throw, just takes a bit of careful measuring and a little bit of welding the 10cm long plate and you can get a nice 30% reduction, any more and the shift becomes really notchy and unpleasant to drive.
