DaisyD
Help!! ABS Value Block?!
Hey
:grin:
Got a couple of ABS errors on my Randy Rado! It's a 95 VR6 and I need to locate the ABS value block - any hints and tips gratefully received?
Errors are as follows ...
259 ABS inlet value, front right (N99)
276 ABS outlet value, rear left (N136)
Cheers
DaisyD
I take it you mean the VALVE block. Open bonnet, look at the back of the engine compartment, on your right looking from the front, mounted on the bulkhead near to and just below the coolant expansion tank. Lots of brake pipes and a couple of electrical connections leading to it.
Best wishes
RB
