Philuk
Rear Brakes Locking After Fitting 288mm to front. HELP!
Cheers mate, appreciate that. Will your offer in mind. Calipers should be here for monday!
My point is that the same caliper was used for 288s and 312s on both Mk3 and Mk4 Golf (plus Bora, plus Passat, etc etc) and you can't guarantee which fitment you're getting. Buy the calipers first and then get the hoses once you know what you have!
I thought 288s off a Mk3 had the screw fitting anyway? :scratch:
the sharans one do, but the calipers dont work with standard setup cause of the piston size, my standard corrado hoses would of fit but i had ordered banjo hoses
