paulg60
supersport coilover question
i have brought some supersport coilovers. the problem i am having is i cant get the back low enough without hitting the bumpstops using 16 inch wheels. has anyone else had this prob. is it ok to leave the bumppstops off or replace them with shorter uprated ones.
Has anybody had problems with the supersport coilovers as mine as when i go over a bump the car jumps up and down 3 to 4 times before it settles. This makes for a very bumpy ride ( headache quite often ) anybody help me
the bounce should subdue as they wear in if they are new.
usuall if the front id too hard they may bounce.
AS for the backs. I use a 5mm spacer with my 7.5x17" wheels so that the spring mount will clear the wheel otherwise it catches.
