level731
ignition switch mount
Hello there I own a 90' vw corrado 1.8l G60, well the ignition switch went bad (left photo) so I had it switched out, my buddy removed the ignition switch. I want to know exactly how I can mount it back up where the key component is. I cant get to my friends location with the corrado, so im wanting to fix it myself but maybe some advice?
hello there I have another situation, on the middle photo you will see a finger touching the tip of the cable which is attached immediately by the black hook . Well that hook broke causing the cable to unhinge like in the 3rd photo, what is the black hook which is attached all the way through the center metal vertical bolt called? without that hook on that cable my accelarator petal is loose
mahalo
Edited by level731
