24V Renshaw 0 Posted March 18, 2012 I am refurbishing my rear struts and have removed the rubber mounting bush from the bottom. Having a look on VAGCAT it appears this is not listed as a separate part, but then neither is the front wishbone bush which you can buy on its own. So does anyone know a part number or somewhere to get this lower bush? I actually have Koni struts but am making the assumption for now that they use the same bush. Jay Quote Share this post Link to post Share on other sites
beastie4126 0 Posted March 19, 2012 Not seen these come up before either, and I would guess that if your strut bush is dead then generally so is the strut so it's all swapped as a unit. Perhaps a call to Koni is in order? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 19, 2012 Does this help?? Has part numbers on too.. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted March 19, 2012 is it the one that the bolt from the rear beam goes through at the very bottom of the shock itself Jay? not sure which bit you mean. If this is what you need i cant see it anywhere either. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted March 19, 2012 Yep that's the one... Will ring VW and see what they say. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted March 19, 2012 Turns out you can't buy the bush from VW, or even the whole strut as they are now obsolete. However KONI have come up trumps, so in a week I should have two original Koni Lower bushes for my Koni struts :) Jay Quote Share this post Link to post Share on other sites
