ray_vr6 1 Posted March 20, 2012 Hi Looking for a bit of help from anyone with electrical/alarm knowledge. My 16v has a Clifford concept 50 alarm which has pretty much every bell and whistle all fitted by a previous owner. He had the door pins removed and led lights fitted in their place along with a switch to operate the central locking which was mounted in the cubby hole beneath the ciggie lighter etc. As part of my winter project I had to relocate the switch as I was fitting oil/volt gauges there. It is a simple rocker switch and I thought I would replace it with a proper central locking switch as it will now be in general view. I sourced one of eBay. It has 5 terminals as opposed to the original rocker switch which had 6 but was only wired to three wires (earth, right and left lock – I supposed) After a bit of experimenting I managed to get it to work ok BUT the central locking operation via the alarm fob would not work. Removed the switch and the fob operation worked fine again. Any ideas how I might resolve the new switch problem? TIA Quote Share this post Link to post Share on other sites
