lukey1507 0 Posted March 21, 2012 (edited) Bring on the bass—extreme power handling with realistic response The Type-R subwoofers just keep getting better and better. Thanks to high-grade materials and optimised design, they reproduce all the low frequencies with extraordinary power and clarity. [subwoofer Power Features] • Peak Power 1500W • RMS Power 500W • Frequency Response: 24Hz - 500kHz • High Excursion 1" Santoprene Edge • Kevlar Reinforced Pulp Cone • Dual Progressive Nomex Spiders with Edge Control • Integrated Tinsel Lead Spider Design • Custom Cast Aluminium Frame with Integrated Heat Transfer Plate • Extended Length Dual-Flared Vented Pole Design • High-Strength Brass Voice Coil Bobbin • Heavy-Duty 10cm2 Push Terminals • Computer Optimized Magnetic Circuit • Designed and Engineered in the USA http://www.caraudiocentre.co.uk/product_m-alpine-swr-1222d_p-21052.htm Kenwood KAC-8103D 1000W Mono block class D amplifier •1,000 Watts max power •250 Watts x 1 max (4 ohms) RMS •Aluminium die-cast heat sink •Built-in variable low-pass filter 50 - 200Hz (24dB/oct) •Built-in infrasonic filter 15 / 25Hz (18dB/oct) •RCA line output terminals for adding additional amplifiers •Power MOSFET switching power supply •Blue illumination •'D' class amplification circuits throughout, using switching techniques instead of the linear methods used in Class 'A' or 'B' type amplifiers. Class 'D' is a significantly more efficient than Class 'A' or 'B', resulting in greater power with less heat generation, higher stability and improved reliability http://www.caraudiocentre.co.uk/product_m-kenwood-kac-8103d_p-22492.htm Please click on the links provided to check the original price. Many thanks Edited March 29, 2012 by lukey1507 Quote Share this post Link to post Share on other sites
