matty golf 0 Posted March 29, 2012 Noticed my high pressure pas pipe is leaking, don't want to pay new prices so is there vehicle using same pipes Ibiza mk 3 golf etc etc Quote Share this post Link to post Share on other sites
owen g60 10 Posted March 30, 2012 Find out the diameter of the rubber pipes and go to GSF they sell various pipes in 1 meter runs... replace the metal pipe if its damaged with same size bent copper pipe... much cheaper Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 30, 2012 Find out the diameter of the rubber pipes and go to GSF they sell various pipes in 1 meter runs... replace the metal pipe if its damaged with same size bent copper pipe... much cheaper you need a pressure hose with the correct ends and unions, you can use a passat hose of the same vintage, probably mk3 golf too. Quote Share this post Link to post Share on other sites
matty golf 0 Posted March 30, 2012 Ok will have to go have a mooch in the breakers at weekend. See what I can find Quote Share this post Link to post Share on other sites
