randal 0 Posted March 31, 2004 Hello, Bit of a funny one this. Started car up last night, had been sitting for about 10-11 hours or so, turned over fine, no problems. However, the temp light flashed constantly all the way home. I waited for the engine to warm up to about 80, still didn't cut off. The MFA red 10 degress outside temp, so nothing funky there either. The really weird thing is, after turning the engine off, and back on again - it stopped. Has anyone seen this before, or got an idea as to what it might be? I'm hoping it's just an electrical gremlin, and not something more severe. Thanks in advance randal Quote Share this post Link to post Share on other sites
Henny 0 Posted March 31, 2004 your water level is very slightly too low... 8) When you started your car, the sensor detected it was low and put on the warning lamp. When you turned the car off, and then back on again after it had been driven, the sensor was now covered again due to the water expanding due to heat... I'll bet that it'll do it again next time the car is cold, but not the time after once it's warm again... ;) Quote Share this post Link to post Share on other sites
randal 0 Posted March 31, 2004 Oh really? Bliiiiimey, thats my kinda fix! I'll check it out tonight. Thanks Henny :D Quote Share this post Link to post Share on other sites
Henny 0 Posted March 31, 2004 Oh really? Bliiiiimey, thats my kinda fix! I'll check it out tonight. Thanks Henny :D I added in some reasoning but you beat me to it with your reply! :) Quote Share this post Link to post Share on other sites
randal 0 Posted March 31, 2004 Yep, it's lunchtime - I'm bored, so it's drop a post *refresh*refresh*refresh :D Makes sense on the reasoning though. I'm 99% sure the water level was OK, but it's odd on those tanks the min/max marks are like 4mm apart. Talk about picky! Cheers again Quote Share this post Link to post Share on other sites
randal 0 Posted March 31, 2004 Henny - spot on, filled the water up a squirt before I started the car over this evening - et voila, no flashing light. That or the car just likes running on Evian... 8) Cheers again Randal Quote Share this post Link to post Share on other sites
