Portent 0 Posted April 7, 2012 Right o... I've already fitted the pods but I kept meaning to ask something. With normal OEM pods they are screwed into the door card and then when the card goes back on the door there is a hidden screw inside the speaker hole which secures the pod onto a bracket on the door. I assume this is to help hold the door card on but also to ensure the pod doesn't move and therefore to give a better sound quality. When I fitted the Audioscapes there was no screw hole inside the speaker hole. It also wouldn't fit onto the door unless I removed the bracket on the door. So I removed it. Is this right? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted April 8, 2012 All correct.. Have you just mounted using only original screws/positions? Most people use about 8 screws per side because of the weight.. Quote Share this post Link to post Share on other sites
Portent 0 Posted April 8, 2012 Thanks. I added extra screws on the lower part of the pods so something like 6 to 8 screws in total per side. But it does feel a bit of a design flaw with the lower half of the door card no longer supported by the bracket. I assume it degrades audio quality a little. Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted April 8, 2012 Early cars didn't have that bracket anyway. Realistically a better design would be something where the speaker is mounted to the door and the pod just acts as a cover. However with my doors fully dynamatted and screwed as yours I'm pretty happy with the sound quality. I think spoonfed offer a better option but so expensive to import.. Quote Share this post Link to post Share on other sites
