Portent 0 Posted April 15, 2012 (edited) I am toying with the idea of retro fitting heated seat pads to my cloth seats. I have got hold of an OEM loom and switch and was testing it out of the car. I want to make sure it works before either going to the trouble of installing it or buying the heated pads. So to test it I have connected what I believe are the live and switched live to a 12v source (black wire and grey/blue wire). The brown is to negative. I then turned it on at the switch and tested the pins in the seat connector with a multimeter. I understand that without the thermistor (which is on the heated pad) I will only get on or off and that the 1 to 5 settings won't change the voltage. So my expected test results were just to SE a voltage of any kind on one of the pins. What I got was a little surprising and I wondered if it was correct or something isn't working quite right... On the seat plug end of the loom the voltage between pins 1 (brown) and 5 (blue/yellow) shows 12v when the switch is turned on (0v when off). But voltage between pins 1 (brown) and 4 (black/red) always remains at 0v. I had thought that black/red would denote live and so had expected it to be 12v. Have I misunderstood or is something wrong with my test? It's great that I can get a voltage on one of the wires but I'm just a little surprised that it wasn't the black/red one. The relays did click when I received voltage. Thanks. Edited April 15, 2012 by Portent Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 19, 2012 Hi there, I don't have a Corrado, but i have Mk3 Golf VR6, so not sure if this will be exactly the same but the principal should be. This is for a MK3 Golf, On the connector that goes to the actual seat, there are 4 contacts, 1 to 4. 4 - GND 3 - SW+ via ignition 1 and 2 - is like a variable resistor, so if you put your meter on Ohms and put you meter probes across pins 1 and 2. You should see the resistance change when you move the heated seat dial from 1 to 5 Hope that makes sense Quote Share this post Link to post Share on other sites
Portent 0 Posted April 19, 2012 Thanks. Will check that. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 19, 2012 I'm in the process of repairing mine at the moment, so I've made a simpler diagram. To understand what all the wires do, i can email it to you if you think it might help you. Quote Share this post Link to post Share on other sites
Portent 0 Posted April 19, 2012 Thanks that would be great. I'll drop you my email although it might be better to post it in here too so it's useful for others in the future. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 19, 2012 I would post it it on here, but in not sure how to as i did it on power point. Please feel free to post it here when i send you it. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 20, 2012 Sent it to you via email, i tried PM you but not sure if it worked due to my low post count. But i have been lurking this place for around 7 years Quote Share this post Link to post Share on other sites
Portent 0 Posted April 20, 2012 Thanks. Haven't received an email. But did get a pm (no attachement). Could you re-send to my email. Thanks. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 20, 2012 Not sure why that would be, let me know if you haven't still received it by tonight and i will try and send it from home. Quote Share this post Link to post Share on other sites
Portent 0 Posted April 20, 2012 Will do thanks. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 20, 2012 You missed the 'g' from your email address, it should be with you now Quote Share this post Link to post Share on other sites
Portent 0 Posted April 23, 2012 Thanks for doing this. Got it now. I've screen printed it and uploaded the diagram here: [ATTACH=CONFIG]60429[/ATTACH] [ATTACH=CONFIG]60433[/ATTACH] [ATTACH=CONFIG]60437[/ATTACH] Quote Share this post Link to post Share on other sites
