n8047035 0 Posted April 4, 2004 Hello all, Im having problems with my passenger door handle. I cant open the door from the outside as when you pull the handle, it obviously is not pulling the mechanism to open the door. It does however open from the inside. So, is it just the handle that needs replacing or is it the whole lot? Any advice on what to do or how to go about it would be grately appreciated as im relatively new to such things (never actually done any of my own running repairs :oops: -but willing to learn and start). Many thanks Amrik Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 4, 2004 If you do a search you will find loads of info - and yes, you need a new handle, theres no real viable repair option. GPC £45 Quote Share this post Link to post Share on other sites
Henny 0 Posted April 4, 2004 that's http://www.gpcvwaudi.com ;) 8) You could also change it for a Passat rear one if you've got a local breakers yard that's got an 88-92 model Passat in it. That gets rid of the keyhole so that would be theives are confused by it... 8) Use the search and put in "Passat AND handle" for more info... 8) Quote Share this post Link to post Share on other sites
