jaxone 10 Posted May 3, 2012 Hello. I recently bought a Golf Mk2 with a G60 engine in it and I have a few small problems among which this strange one with the temp gauge. The temperature gauge will never go more than 1/4 of the temperature scale. First I thought it is my gauge in the cluster and I replaced the whole cluster with a Figifiz cluster. On the new cluster the same, the temp will go at max 25% of the scale. Then I replaced the sensors, both the black and blue one ... same thing. I took 2 other sensors from another engine .. still the same issue. Isn't the black sensor the one that sends the temp reading to the cluster ? So with 2 sets of sensors changed, two different clusters (one analog and one digital) and the damn temp gauge still not working properly what else could be wrong ? Can be a relay ? Can be a bad earth somewhere ? Any other known issues ? Thank you in advance. Quote Share this post Link to post Share on other sites
jaxone 10 Posted May 10, 2012 Replaced thermostat, everything ok now regarding the temp gauge. Quote Share this post Link to post Share on other sites
