manop001 10 Posted May 25, 2012 Hi all, Seen some rims for sale on Ebay but they are 4x98 (once on a Fiat Punto) but they guy is selling the rims with some kind of adaptors that will make them fit 4x100 cars??? Is this possible? Thanks all! Quote Share this post Link to post Share on other sites
KADVR6 0 Posted May 25, 2012 well you could use wobble bolts, but was is the centre bore for fiat alloys?? you may either need them machined out, or some spiggot rings. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 25, 2012 ive heard of such a thing as "wobbly bolts" that would work. I woulnt fit them but some do. Quote Share this post Link to post Share on other sites
manop001 10 Posted May 25, 2012 Bore on the Fiat is 58.1 Corrado is 57.1 Quote Share this post Link to post Share on other sites
leon263 0 Posted May 25, 2012 ive heard of such a thing as "wobbly bolts" that would work. I woulnt fit them but some do. The term 'wobbly bolt' probably sounds a bit suspect but if you give them their proper name which is 'PCD correction bolts', then they don't sound so bad. I can assure you that there is absolutely no problem with these bolts, do you honestly think that they would be on the open market if there was. I ran 5x100 wheels on a 5x98 Alfa many years ago for over 3 years and 40,000 miles and I'm still here to tell the tale. You will need spigot rings to reduce the centre bore from 58.1mm to 57.1mm and assuming the the off-set is reasonably close to the VW off-set then you will have no problems. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 25, 2012 (edited) I dont care what they are called. I merely said that I would not fit them.... what you or anybody else fits is not my concern but I wanted to answer the guys question so I did. Edited May 25, 2012 by VAG-hag Quote Share this post Link to post Share on other sites
Erny 0 Posted May 26, 2012 Chris wobble bolts are perfectly fine, its merely a collar that has a little room to move to seat perfectly in the wheel. Used in various engineering aplications. I was very jubious untill i had one in my hands. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 26, 2012 fair do's big Ern.... Quote Share this post Link to post Share on other sites
