C5 OEM
vw sharan 1.9tdipd limp fault
So had this fault for a few months now and happens 20% of the time at around 3500 revs going uphill.Mechanic has had the turbo off and cleaned and replaced the n75 and egr valves..... anymore ideas...? its driving me mad..... and with it being a sharan the access to the turbo is crap...!!! doing my head in..
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
Change the MAF if original.
Possible Symptoms
Limp mode
Possible Causes
Possible Solutions
see if the actuator rod is moving freely, if not its easy to lubricate
Edited by KADVR6
Think its gonna be turbo off again and double check its all moving then pull pipes off...
Without looking i'd say turbo actuator, don't think it's separate from the turbo on the 1.9TDi but there may be a non genuine alternative.
think it can be separated and vac tested.
